Bumper Beading - Maestro Turbo
  • Bumper Beading - Maestro Turbo
    Hi everyone, does anyone know where I can get black bumper beading for a red turbo. Thanks in advance, Simon
    Part numbers you need are rear - DQA10032PMA and fronts (you need 2) - DPR10044PMA. A site called mgrovergenuine.co.uk appears to have the fronts in stock but the rear is an NLA part now. One option would be to get the claret version (last three letters COD rather than PMA) and then cover them in black vinyl tape, or even cover your current ones in tape if they are in OK condition.
    Membership Secretary
      Wow, amazing detail, thank you.
        Pete, could you hit me with some part numbers for a battery clamp please. I appear to have a new tray but battery is held in with cable ties. I'm guessing it had a clamp originally. Simon
          The clamp changed partnumber after VIN 603219. (Don't ask me why or what the difference is!) Before it is EAM8450 and after it is YJF10004. You will also need an 40mm long 8mm bolt to fit the clamp to the tray. The early clamp is NLA. The later one is available through XPart dealers (Rimmers for example).
            That's great thank you.
              So my vin is 589720, do you think the later one will work?
