  • Excellent! I'd forgotten about the vacum operated heater controls...
    • Yeah only early models had this feature John. All back in now and working properly. Dash wiring tidied up, all door wiring now sorted with putting in the door sleeves, poxy job that. Interior light now working, dash nearly ready to put back in with just the foam to sort on the heater junctions with the dash. Also sorted the rev counter not working and various display lighting not working. I will be putting in one of three digital dashes I have and will be using the best one. Also replaced the rear spoiler with a better one. Assuming this is teething troubles already as the car has started to 'miss' a bit when cold on revving it, ok when warm though. Will have to look at that in the future, also a couple of water pipe started to leak a bit, sorted that , and the oil pump developed a leak from the top main rear bolt, tightened up and stopped but I didn't touch that so maybe leaking before the strip down
      • The only thing more annoying than leaks at this stage are leaks when it is in the mot bay! sounds as though it is all moving in the right direction though, fiddly little electrical faults can take a long time to sort out, as I have discovered more than once......
          As the mot won't be till spring there are plenty of opportunities for fixing any leaks, well that's the theory, as with electricals time will tell. Still haven't filled the gearbox with oil and filled the brakes with brake fluid yet so hopefully that won't leak,
          if the foam turns up this week I should have time to put the dash in before Xmas, happy days
          • Dash in today, new foam in, had to change the centre as the original is damaged
            • On an older type dash the steering column has to be removed due to this square hole
              • All in now, there's also a rubber strip behind the dash on early types. Screens next
                • Due to various reasons, my mum passing away and my dad about to, the car will be delayed till maybe late spring, April/may sometime. Not got the time or inclination atm and won't have till near end of February/March
                  • Hi Jeff.
                    Sorry to hear about this but family must come first.
                    All the best. Ian
                    • Originally posted by carfix View Post
                      Hi Jeff.
                      All the best. Ian
                      Thanks Ian, while sorting various things, probate, funeral etc I got a great quote to put the windscreens back in as a flyer landed on my desk, so that's happening next week.
                      • Screens are in
                        • And rear quarter lights, this is the last major thing so all the big stuff has been completed
                          • More done today, last of my new scuttles on and associated parts
                            • Bonnet insulation on and front rubber trim
                              • And bonnet back on
