Need to replace the rear wiper on my Maestro. The one on there is about 400mm long, but all the replacement option suggest 500mm the same as one of the front ones. Does anyone know the correct size to get.
rear hatch wiper blade size
EPC shows same blades for both front arms and a different one at the rear. GWB340 Front, and GWB329 Rear. Googling those part numbers doesn't come back with anything useful, except one site that possible suggests the fronts are 20" and the rear 18". Early maestros were the same all round.Membership Secretary
Officially, Maestro's used 20 inch wiper blades for both fronts and the rear. So get a 20 inch one, preferably a Bosch one from GSF. However, personal experience has proved that on the front wipers of a Maestro, you can use 21 inch wiper blades without any clearance issues. Again, personal experience proves that Bosch are the best.
