As far as I am aware the inner steering columns are the same across all models and have the same diameter spline. The only difference being with the double U/J -The PAS one has a larger spline at the rack end to suit the larger diameter pinion in the PAS rack but both are the same length
This would mean anyone converting from non PAS rack to PAS rack would only need to change to the PAS U/J to have it all connected up
Can anyone confirm this is correct?
Ross
Ross
