maestro van wheels help
  • maestro van wheels help
    hi all I have just bought a maestro van and want too put some alloys on can anyone tell me if mgtf wheels fit ,as I want too put those red brakes on also I think there are ap 160 ,I think,also someone has said bmw mini wheels will fit any help adive please
    Van wheel pcd is 4 1/2" same as an MGB, so TF wheels won't fit, but some Rover 600/800 ones will.. https://www.carlsalter.com/rover-wheel-fitments.html has been converted to mm , which is not always a smart move but might give you a few clues...I think there is a bigger list on internet somewhere too, but can't remember where.....
      Many thanks for that very helpfull , on a new note has anyone just put car hubs on front and back so they had a better choice of wheel can that be done
        It has been done I believe, the front is simple, as you can just change the whole spindle over, on the back I think car stub axle , or van axle end is to redrill. I think some have been converted to 100mm metric pcd too, giving an even bigger selection of wheels, but involving a bit more work... It all depends what wheels you like, there are quite a few available for MGB I think and there were some Japanese cars with 4 1/2" pcd...
        good luck
        John
          hi cheers for that has any member on here swapped over hubs just so I can see how its done many many thanks
