Maestro turbo auto choke
  • G588OEA
    started a topic Maestro turbo auto choke
    How many of you turbo owners have converted to manual choke vs keeping the original system ?
    In my quest to get mine working Iíve come across the first hurdle of finding itís got the wrong ECU, Iím guessing it needs to be a turbo specific one before I can start proper fault finding or just bin it off and convert to manual
    After some thoughts and opinions please
  • G588OEA
    replied
    Big thanks to Sussex Pete for supplying me with the correct ECU. Another job ticked off the list
  • Jeff Turbo
    replied
    Yep the same
  • G588OEA
    replied
    Ok thanks Iíll add it to my list of things to try and obtain !!
    Is ADU 8499 found in both maestro and montego ?
  • Jeff Turbo
    replied
    Electronic control for a turbo is ADU8499, the one in your picture is for a 1.6 Maestro. Once you've changed that check the O rings on the auto choke as they perish with age. You will need Viton replacements that are widely available
  • ian drew
    replied
    The Auto Chokes aren't as bad as often made out. I'll check to see what numbers mine has written on it, but I would be surprised if that isn't the correct one. The other 2. lire MGs had fuel injection and no carb so the auto choke would have been completely different.
    Ian
