Hi All, Ok drove it down from north wales- apart from slight splutter now and then all ok... following day drove it 30 miles to get some advice on bodywork on parking up was very low on fuel... 2 weeks later ive tried to restart it it coughed into life then died within a couple of seconds.... Now i've added 4.5 litres of fuel as i suspect it may have been empty/run out as i parked it. Car turns over well - thou now need to recharge the battery... Is there anything i need to look out for specifically? I'll need to check i have spark (have new leads plugs (look new on outside) rotor arm and dissie cap ) also have new fuel filter oil air and new oil as intended to do a full service as soon as i had time. There is no reprime fuel procedure or special start up is there? i've quickly checked plug leads and coil connections but not yet had time to dig int it just hoping its something simple as it ran fine 2 weeks ago and started within 2 seconds no problem....
The New MG 2.0 wont start..
My hearing is rubbish these days - so cant say ive heard the pump will try adding a bit more- Is the pump at the rear axle like the montego manual says for its efi? Thanks for the info Kobe as i've had no maintenance history for the car.
Silver MG Maestro - C555, needs some anti rust love
ok tried some more fuel - no go - some easy start and it turns over and dies... so my guess is no fuel... i can hear a squirt when i turn ignition off - fuel return to tank? cant hear pump will locate pump then get someone to try starting car - or try fuel filter change then....Silver MG Maestro - C555, needs some anti rust love
There may be a problem with one of the two fuel pump relays mounted on the passenger's side inner wing: One of them energises the pump to get the car started, the other takes over once the engine is running.1983 (Y) MG 1600
1987 700 City 1.6 Van
1988 Tandy camper 2.0D
1990 Clubman D
1990 MG 2.0i (spares donor)
(all Maestros)
Daily drive: Rover 25 GTi
When these cars run out of petrol they end up sucking loads of crap up from the bottom of the tank and then blockages can occur. That along with the fact that it didn't like being low on fuel before won't help. I wonder what state the fuel pickup is in inside the tank, possibly corroded and therefore shorter? You could try wiring the pump in continuously, that would rule out the fuel relays etc. I recall in the past another forum user spending a fair amount of time and money on a problem where when fuel low and turning left hard, the car would die and refuse to start, turned out to be the corroded fuel pick-up and the lines being full of crud.
Good luck!
Ian DIan Drew
finally got a chance to work on getting it running....tried swapping relays over - no difference - checked voltage getting to pump ...3.7 volts... tried switching it direct from battery 12.3 atbattery but only 6 volts showing at pump - shorting? At least it showed willing to prime with 6 volts... also noticed the twisted wire connections to spade connections that are there... must have been a reasonable connection as its been running like that for some time... took 10 minutes to fit new spades and get them to fit properly....
so next is change fuel filter and pump when it arrives and try again.
underneath will need some cleaning and underseal but not bad otherwise... also the fuel filler breather hose needs some attention...Silver MG Maestro - C555, needs some anti rust love
Originally posted by neallew View Postfinally got a chance to work on getting it running....tried swapping relays over - no difference - checked voltage getting to pump ...3.7 volts... tried switching it direct from battery 12.3 atbattery but only 6 volts showing at pump - shorting? At least it showed willing to prime with 6 volts... also noticed the twisted wire connections to spade connections that are there... must have been a reasonable connection as its been running like that for some time... took 10 minutes to fit new spades and get them to fit properly....
underneath will need some cleaning and underseal but not bad otherwise... also the fuel filler breather hose needs some attention...Last edited by Jeff Turbo; 8th July 2019, 14:03.1958 Ford Consul Convertible. I love this car
Yes live and earth tried - initially from car reading 3v (switched from ignition original circuit.) when directly switched from battery it would still only apply 6v.using something like this Automotive Circuit Tester Power Circuit Probe Kit - DC/AC Current Resistance Diodes Vehicle Voltage Signal Diagnostic Activating Components Tools VXDAS VSP200 for 12V to 24V Electrical System
.. 15l of fuel have been added - Inertia switch also checked no sign of red but pushed button down anyway and it didn't move.. anyone have the correct part number for the 1986 fuel sender or pickup unit? id like to see what i have - i think i just have a normal fuel sender as the pickup pipe seems to come straight out of the tank into fuel pump...
If i read it right one relay does startup the other running so wouldnt it at least prime it if riming one was faulty? then start running and then die? Having read the efi owners book it just says to start for 6 seconds wait 30 then try again to "reprime " the system...
Once fuel pump arrives will fit that - is it worth putting a plastic fuel filter in line before it just to see if crud in tank? as a temporary measure? to protect new pump?
all suggestions and ideas are gratefully received..
We had a none starting 2.0efi. We got nothing when turning ignition key accept the engine turning over.
No fuel pump priming, stepper motor rattel.
Are problem turned out to be no earth to ecu. We earthed the yellow brown wire (ecu earth ) on first relay under the bonnet. The car then started.
Don't no if this helps but worth a try.
Alan
