Maestro wheel bearings
  • Maestro wheel bearings
    I notice on ebay there are one piece replacements, are these better than the original 2 bearings seperated by a spacer ?
    First of all, front or rear and the year of your car?
    2002 MGZS 180. Cheap 50 car
      If its the front hub then there are two bearing options.
      A two piece bearing for earlier cars and a one piece larger bearing for later cars (which is supposed to last longer).
      I don't think they're inter-changeable as the hubs are different.
        there are two types of one piece bearing as well, ball thrust and taper roller, Rover discontinued the ball thrust fairly quickly as it was prone to failure, but they are still available nos or pattern parts, best avoided if possible.
          it is the rear wheel bearing and the car is a 1998 Ledbury
            it will be a two piece bearing, make sure the hub/drum is not worn. Is the old bearing rumbling?
              As above, A two piece bearing and you will need to keep the spacer in the centre as bearings don't come with it. Easy job to remove
                Thanks a lot chaps have ordered the two piece set
