Hi all,
Got a few little problems changing the timing belt.
Firstly, i'm having trouble removing the water pump pulley bolts, simple enough, but am I missing something?
Secondly, in the absence of a scissor type tool to hold pulleys still, is it really necessary to remove the camshaft pulley?
Can't the timing belt be just placed over the pulleys? If I just remove the tensioner will that give enough 'play' to allow me to fit the belt?
Also has anybody got any tips on doing this job, i'm following the Haynes manual. Enough said.
Dean.
Dean.
