Hi, I have got a montego 1.6 sl from 1989, I still have problems to start it the first time of the day. It takes a lot to start and if you do not accelerate it a bit to the first time the engine shuts down. I have looked at the steeper motor and turn, also I changed the rubber rings. The fuel pump is also new. Once a little time passes the car is perfect, it does not hit jerks and the idle remains stable. I have been told to install an electric gas pump that will power the circuit. Also I am thinking to buy a new carburetor in http://sucarb.co.uk/ I don´t know how I can do to fix this problem. I understand that it has to be something of the carburetor, what do you recommend? Thank you very much, best regards
Problems to start Montego 1.6
Montego 1.6 SL 1989
Golf V 1.9 TDI 2004Tags: None
