Montego 2.0i 1991 right angle top thermostat hose to coolant rail underneath manifold
  • Montego 2.0i 1991 right angle top thermostat hose to coolant rail underneath manifold
    Hi all
    I am referring to the right angled top hose that connects just underneath the thermostat to the coolant rail beneath the manifold, Its about 5inches long when straightened, but is right-angled, and has a 3/4 top internal diameter and 5/8 bottom internal diameter.
    I was wondering whether anyone knows where you can obtain this item from or even what it is called? Are there any alternatives?
    Thanks in advance.
    LPG Converted Montego 2.0gsi 1991 - are there any others?
    is this the one.
    https://rimmerbros.com/Item--i-UAM5630EVA
      Yes that is the one. Thank you
