developed gearbox
  • developed gearbox
    Does anyone know which gearbox has the longest development? I have a montego lxi and I want a more relaxed development. I found a gearbox with reference 1988 2. 0 k6a0 2013623. Does anyone know if this gearbox has a longer development than that of my gearbox lxi?
    This page has a list of different ratios. for each gearbox code, you will need the code from your gearbox to compare. https://wiki.seloc.org/a/Rover_PG1_gearbox
      Do you know what model this gearbox was mounted on? Is the reference number correct?
        K6AO is a number that should be for a Montego gearbox for 2.0 petrol I think.
          So is it supposed that the gear ratio is longer than my momtego lxi?
            not sure, do you know the code for your gearbox?
