Pin holes galore in the heater pipes, inside and out on two cars ! So made a set for the diesel turbo, one other set is already in the MG Maestro working fine:
Standard 15mm copper pipe for the plain pipe - used yorkshire fittings on the ends - they fit the hoses perfectly and even provide the 'bump' for good retention. Just flattened pipe for the supports from the manifold.
Inside car heater run more tricky - needed to make a jig for this. Same 15mm copper, plus brass plate for the heater matrix interface. Needed the jig here to get the correct spacing and protrusion, ready for the O-rings. Bulkhead plate is Ally, fixed to a brass channel, which the pipes go through (soldered). Just need a spacer for the intermediate fixing to the heater box (cut a corner here to make it simpler)
These won't corrode !
But didn't half take a long time though
