Originally posted by Jimarilo
View Post
Just bought a Maestro .....
Hi Jeff, I flushed the pipe that comes off the inlet manifold and through the heater matrix ??
I replaced that pipe as it was too short as it had been cut and joined to the pipe on the other side of the manifold, by passing the manifold as the manifold unions were too corroded. I fitted new unions and re-connected the manifold
However I will be getting a second chance if not as I am now going to fit a new old stock radiator, when it arrives
I went in the garage the other morning to find coolant had been leaking from the bottom hose on the rad. It was leaking when I filled the system, but looked to have sorted it's self after tightening the clip. Obviously more to it than that. It looks like the original radiator and looks a bit iffy in a few other places, so managed to find one at £35 ......
Originally posted by Jimarilo View PostHi Jeff, I flushed the pipe that comes off the inlet manifold and through the heater matrix ??
Thanks yes all is going well, but have two other cars to keep on the road, so the Maestro only gets work done as and when. It is the lucky one as it is kept in the garage
Fitted the new radiator as well as anew sender switch in the rad. The old rad when I took it out was only just hanging together lol . So no surprise there was a leak
I took the car to the local garage to put some fuel in and it drove really well .....the next fix is the rear exhaust which is blowing, but may as well put the whole system on, when I can find one
This car is on you tube 3 years ago, still only done 49k The buyer at the auction is the chap I bought it from. It was used for period dramas and movies so didn't do much driving about mainly sat in a garage https://www.youtube.com/watch?v=WTiDqBzjOUY
