MG Montego efi
Well I did try. Removed the knackered sunroof glass and got all ready to put the replacement in but the seal is too large/thick so the glass is stuck and the motor won't move. Removed the seal from another I have in my spares and ordered another as I couldn't find the one I bought 4 years ago. I sold on a few things 2 years ago and wasn't sure about the seal so ordered one for a mk2 GolfLast edited by Jeff Turbo; 4th November 2024, 15:34.
Originally posted by Doctordiesel77 View PostAll's well that ends well, headliner and dash should be the easy bit...especially when you wrote the 'how to s' on hereLast edited by Jeff Turbo; 3rd November 2024, 14:37.
Presents turned up today and a bit of research goes a long way, sunroof now working. Hasn't moved for many years up took it slow and easy, up down up down, back a little then front, back more then front until it goes all the way back. Plenty of WD40 and spray grease it now moves much better. Still a bit crunchy but that should ease up. Change the glass next then I can do the headliner and put the dash back inLast edited by Jeff Turbo; 31st October 2024, 13:22.
Originally posted by Doctordiesel77 View PostI might have some springs and brushes if you want to fix the old motor.
Started looking at the sunroof not working. There is power to the electrics then noticed this. As the motor is probably broken I stripped the end as I know its the same basically as a dynamo but a tiny spring went ping from one of the brushes and I couldn't find it so that's now scrap, not good and I did swear quite a bit
After doing a bit of research I found it's the same motor as an early Rover 213/216 and a Range Rover tin topped sunroof up to 1991. Found one complete with a relay so that's on its wayLast edited by Jeff Turbo; 27th October 2024, 13:41.
Then took out the headliner, windscreen had been replaced in the past as some of it was stuck to the screen .While it's out I will check on the sunroof motor as it's not working and also replace the glassLast edited by Jeff Turbo; 31st October 2024, 14:09.
Don't you know it,lol, and your million miles estate piddled quite a bit of oil on my drive btw
Originally posted by Doctordiesel77 View PostLots of fun to be had there!
Interior removed and now all ready to start grinding out rust and continue practicing my welding. It's mainly the rear box sections, a few things on the sills and I'm hoping to tidy up previous welding bodges.Last edited by Jeff Turbo; 8th September 2024, 11:24.
