Came out not too bad there John, nice work
Black Efi resurrection
Next time? You only want to do this onceOriginally posted by Doctordiesel77 View Post
Cheers! I should have taken a before picture...next time maybe....1958 Ford Consul Convertible. I love this car
This weekend's work looks like I've been busier than last weekend, even though I haven't! I added plenty of white paint pointing to the timing marks, which aren't always easy to see. My spare cambelt tensioner turned out to be one of the harder to find early ones when I opened the box, so I've ordered one of the correct ones to put on next weekend.
New cambelt tensioner on, the Haynes and early Rover workshop manuals don't give tension figures for use with the Rover belt tension gauge, but the later Rover book does, 5 to 7 is the acceptable range, so I set it at 6. Not quite ready for the PAS drive belt yet, but I got one out ready. The correct part is GCB 50765, which is a belt 765mm long and 11.9mm top width with high ride out, you can see it sitting proud of the pulley in the photo. If you get a belt that doesn't sit proud of the pulley it is certain to slip, which is why I made a point of getting a genuine one. The RH engine mount was the subject of a technical bulletin, the bush was prone to wandering out of the housing, fix was a self tapper, or pop rivet, I used a self drilling screw which should be a bit stronger. Now to work out the breather hoses...
John, how did you get the dust shields to go in on the calipers? Ignore that as I sussed itLast edited by Jeff Turbo; 15th January 2026, 14:33.1958 Ford Consul Convertible. I love this car
Connect up the rear water pipe to the thermostat housing before putting the engine back in as it's much easier. Looking good there John, later engine too so parts not readily available, but you should have most of themLast edited by Jeff Turbo; 26th May 2026, 07:55.1958 Ford Consul Convertible. I love this car
Pressure reg looks the same as a Jag but different part number https://www.ebay.co.uk/itm/306813736...Bk9SR7Dx0YbNZw1958 Ford Consul Convertible. I love this car
Very true, but just once per project still leaves a few next times....
