BLOG: race/rally MG Maestro 1600 - "Pink Panther"
  • #76
    Spare tyres
    Hi John, looks like your continuing to makr great progress on the car. Just a quick note, that within the spares package are a great set of trackday tyres on beadblasted and powdercoated rims (white). These have enough tread for road use, but would also be fine for getting the tracking done. That was what I used when it was last set up in 2011.
    There should be two good Colway intermediates thatI purchased new for the car as well. The others were secondhand and came with the car, so are at least 14 years old now.
    Nick
    • #77
      Excellent progress John
      • #78
        Thanks Nick & Jeff!
        Latest update:
        After careful research on noise levels, etc. I've taken the plunge and ordered a Custom Chrome 'Cherry Bomb D.I.V.E.R' exhaust:
        http://www.custom-chrome.co.uk/shop/...ex.php?cPath=1
        This has a couple of half moon baffles in it (and also a 20% restrictor made of perforated material) to make it quieter.
        Graham of Custom Chrome (CC) advised that a cherry bomb centre box may also be necessary to bring their silencer's volume down to noise limits, but recommend going for the longest and fattest silencer possible to reduce the noise. I've just spoken to Ray (very experienced Rally co-driver) at the local Rolling Road and he said that Cherry Bomb's are noisier than anything else around, so recommended going for the DIVER to get the noise down to a reasonable level. He also said that the slightly increased back pressure is unlikely to make any difference on the rolling road (plus the older Austin engines e.g. Mini etc. actually do better with a bit of back pressure).
        At present, the exhaust pipe (which is 2" OD) is chopped off behind the rear axle. However, it has a 1/2" long extra flange at its rear edge (which is 2.25" ID). Therefore, I presume that we need a 2.25" ID silencer inlet to slip over the existing pipe?
        We also had a sesh to sort the Battery box and make its lid (and the box itself) strongly enough attached to be 'roll proof'.
        This involved replacing the self-tapping screws with beefy bolts (and big washers) after drilling out the holes. We put in a metal '2 bolt' battery strap and joined the 2 bolts up underneath the box's floor (with a cable tie or 2) to add extra strength against the J-Bolts straightening out/pulling through in a roll (I have had this happen going round a bumpy field rallying a Mini once!).
        We also rust treated and then painted:
        a) The bolt holes and edges of the floor where it had been cut through (red Hammerite)
        b) the top of the cross beam that will be obscured by the box when it's refitted (Screwfix Galvanising spray paint and then Wickes silver metallic metal spray paint)
        We also cleaned out the spare wheel well and fitted a foot press button for the co-driver's horn.
        • #79
          ++++++++++++Sun 10 Nov 13 - Targa Rally - MOD Woodbridge, SUFFOLK
          The event had a difficult start when the scrutineer was awkward about the door handles, so I had to bodge a 'pull cord' onto them, not to mention some conflicting gen on when to scrutineer/sign on which put us dead last to get the process. The event started for me and my co-driver David Cammack with lots of handbrake turns on the stage. The HB worked well on slippy surfaces but on the tarmac, the car either spun virtually to a halt (resulting in lots of lost time trying to get the notchy gearbox into first not reverse, as the lever's detente isn't working), or the back end didn't unstick at all. By going into the corner too fast but being still on the brakes as you turn in, it worked better but Ding Boston (OUMF) doesn't use the HB at all and he is a front runner so I'll try this next time. However, the HB was great to throw the car through 90 degree bends on the loose/slippy areas.
          Several cars were spotted off the stage e.g. beached on a bush at the end of a buddleia section, and one had a wonky rear wheel angle from clouting a kerb (unsurprisingly he was subsequently turned away by the start marshal!).
          We had a late co-driver spot of the next gate, which resulted in an overshot of the corner over the top of a bush (which resulted in a bodge tape repair of the front air dam being needed).
          Nick Grahame (fellow member of http://christiansinmotorsport.org/) was there in his MX5, and was good craic, as always. Thanks also to Nick for the loan of various tools/items to do the above bodging.
          We had some classics out on the stage e.g. coming the wrong way round a grass island to the passage control checkpoint and being sent away by the marshal to come back around from the right direction! As a result, I was pleasantly surprised to see that we weren't last overall -in fact we still beat a number of other cars, which topped off a great day all in all.
          • #80
            The old exhaust system had no centre box and for its rear box it had a rotted out straight through centre silencer! With this system in place it was very noisy. With the new Cherry Bomb DIVER in place for the Woodbridge Targa Rally (Nov 13) the Noise check showed a very reasonable 83Db. However, the exhaust had been bodged on the day before with an ARC welder (and so it had to come off to be put back on properly (without leaks, knocking on body and pointing straight).
            • #81
              Had the car rolling roaded on Thursday 12 Dec 13 and it needed no re-jetting, which is good.
              It is producing 116Bhp at the flywheel, and Ray concluded that it must have a camshaft with a modified profile.
              I think this is a strong output for a 30 year old engine (and a 40 year old design)! Anyone else got any views on the achievable tuning output from the R-Series 1600 (which produced 103Bhp as standard when new 30 years ago)?
              [separate thread also refers: http://www.maestro.org.uk/forums/sho...608#post168608 ]
              • #82
                rolling road
                Hi john that's good isn't it, where did you have it done,? near you?
                • #83
                  Hi John,
                  Enjoyed reading your Blog. All good work. I fitted a Janspeed exhaust system on my Maestro and got 100 mph before braking at the end of the back straight at Snetterton, whereas with the standard Rover item I hadn't previously got above 90 mph.
                  • #84
                    Thanks Pete!
                    The car was rolling roaded by T&M Auto Electrical of Colchester:
                    https://plus.google.com/114633237538...ut?gl=uk&hl=en
                    old school boys who each have 40 years of experience in the trade -just the job
                    • #85
                      We're having some problems making the seats fit at present.
                      We might need to bolt some of this stuff:
                      1 x Aluminium Rectangular Tube (1"x1/2"x16SWGx1000mm) Metal Alloy Box Tubing
                      http://www.ebay.co.uk/itm/1-x-Alumin...item35c7bb5115
                      across the gap to enable the seat mounts to be sited closer together.
                      or possibly cut (& drill) some metal plates along the following lines (the OMP components are a rip off for what they are):
                      OMP ADAPTOR BRACKETS
                      Prod Code: OMPHC729
                      http://www.jjcraceandrally.com/kit-c...aptor-brackets
                      • #86
                        I robbed the fanbelt from this car to keep the white Maestro going at the Autocross. I drove the car 400m up to the garage with no fanbelt but it didn't appear to get overly hot in the process.
                        The new component to fix the suspension has arrived
                        I see that the car is eligible for this category:
                        49.1.4. Historic Category 4 Rally Cars:
                        Includes cars registered and homologated in Groups A,
                        N and B between 1 January 1982 and 31 December
                        1985 excluding any cars that were regulated out by the
                        FIA in period from rallies for safety reasons. Cars in
                        Category 4 must comply with their Homologation forms
                        and Appendix J of the 1985 FIA Yellow Book.
                        Cars homologated in Group B with an effective engine
                        capacity exceeding 1600cc must have been issued with
                        a valid FIA Historic Technical Passport (HTP), be in
                        compliance with this document and the current FIA
                        Appendix K at all times
                        https://www.msauk.org/assets/281324s...rrallyingr.pdf
                        • #87
                          Car needs the following put in it before it goes back to Autoskills:
                          -harnesses
                          -rear view mirror?
                          [N.B. its keys are already in it]
                          We also need to purchase a lower ball joint for it
                          • #88
                            The Pink Panther has been requested by Nick and he has now got it on long-term loan TFN (hopefully to make its first appearance this year at the famous and very popular Ormskirk Motorfest http://www.ormskirkmotorfest.com/) on Sun 30 Aug 15.
                            Nick's got the following with the car:
                            1x Haynes manual
                            Wheel rims: 4 cheesegrater type
                            Wheels (rim & tyre): 3 cheesegrater type (+ 1 spare wheel in boot of car?)
                            Halfords car cover (in large green holdall)
                            2x black bucket seats
                            Various pink colour items: spray cans, masking tape, face paint, paint pen, insulation tape etc.
                            Battery-powered Interior lights: round silver LED light + a black filament torch on a sucker (missing its battery cover)
                            Self-tapping screws & washers to hold the lid of the battery box on
                            NUMAX 12v battery & spacer (to go below the lid)
                            Keys & battery cut off
                            Black plastic portfolio File with MSA logbook, V5, MoT etc.
                            Alloy sump guard (from one of the ex-works Maestros)
                            Gearbox (possibly seized)
                            Metal tubing: 2 lengths (to fabricate seat mountings)
                            Rear strut brace
                            Nightstick alarm lock & power cable (rechargeable 9v batteries inside?)
                            Harnesses: 2x blue LUKE (4 point)
                            Washing line (blue) -to be made into door pull cables
                            Magnetic oil filter attachment
                            Throttle cable
                            red windscreen squeegee
                            Austin Rover jack (black)
                            Wheel nuts
                            Mudflaps: 2x red
                            Lower ball joint (NIB)
                            Flashlube (in a Castrol Valvemaster bottle)
                            The soft furry Pink Panther in the rear window was evicted by Nick (so remained here)!
                            If the exhaust develops problems in due course then Nick said that he may use this firm to get one made in Stainless steel (which will probably be about £400): http://www.pipewerx.com/
                            Nick found the reason for the clunking. It wasn't what we originally thought (a worn lower ball joint). It was actually the bolts loose on the nearside caliper -causing it to bind on the wheel! The caliper was removed and secured out of the way with cable ties.
                            • #89
                              Found a replacement new windscreen for this car (in garage roofspace)!
                              Nick reckons it is bonded in but that he can fit it for 2 tubes of SIKAFLEX (which will be about £20), or we could always get a fitter to do it.
                              • #90
                                Update from Nick:
                                Car is now at the body man we use in Southport and will be getting a respray to tidy it up. Get rid of the various shades of pink!
                                Let me check later this week on his time scales but can't see why the windscreen couldn't be fitted there.
