My car has a dreaded leak into the front footwell, on the driver's side. I've had the plastic panel off the bulkhead and found this:
Should there be a gromet or something in there? I'm not sure whether to fit one in case it is meant to be a drain hole, as the top of the bulkhead seems to be a tray for incoming water from the wiper grilles/scuttle.
