Hi everyone,
My maestro has a HIF44E on it at the moment, which I'm planning to get rid of as it's causing problems with the idle and cold starting, and I suspect it has somehting to do with the poor MPG. I have a metro HIF44 to put on it but I am having problems with where to mount the throttle cable. The mini/metro spacer plate bracket thing which the throttle and choke cables mount to would sit directly underneath the maestro air box, meaning I either need a new way of mounting the throttle cable or a different air box. I have ordered an Ital cable as the maestro/montego cable does not reach the front of the carb and the Ital one is 4 inches longer.
I suppose my questions are, is there another airbox I can use which doesn't interfere with the cables, and has anyone else done this conversion and know of any other problems I might encounter?
Regards,
Ben
Regards,
Ben
its not wroth it and is far easyer to sort out the running problems which will the give you years of hic up free motoring
