I took my car to Austin Garages for them to fit a recon burlen carb, which they have, and what a decent job it is. Of course, taking my car there has flagged up other issues which I was only semi aware of, namely engine mounts.
How easy is it to remove and refit the right hand engine mount for the maestro turbo? I guess it's a case of using a jack and a block of wood under the sump and removing? Is there much to remove out the way to carry out the job?
Saw on mgcars bbs that one shorter term solution is to turn the rubber in the mount around using a hammer and punch when it's off the car.
*Somewhere* I have a new gearbox mount (just got to find it!). Found a fairly good used side mount yesterday and have another on a spare engine. Also got a good used gearbox mount.
