i have noticed that the overheating light comes on when the temp is on normal, this when I think about it has gradually got worse over the years, the engine does not overheat, just the light flashing.. does anyone have a wiring diagram for the dash, or can explain how it works to me.. if it is the dash i probably have a spare somewhere among all the junk i have here.. thanks in advance.. ricky
The Mad Maestro
Overheat light is probably the autochoke ECU that is playing up if it comes on straight away. The fusible links which I think is what you mean are about a foot long from memory. They don't go very far into the loom near the battery.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
dan I think you are forgetting I am running a mems 1.9 wasted spark system, I don't have separate ecu's anymore... the wiring I have sorted just cut it back almost to the bulkhead, then found the info in the Haynes manual, the overheating light I thought would be linked to the dash/temp gauge and maybe a resistor problem, as both the temp senders are relatively new and the gauge reads ok....regards rickyhome of the "mad maestro"
rover sterling kv6 and four tailpipes on lenso rs5's
1935 Morris 18/6 being rejuvenated with xj6 parts
turbo fitted, wiring sorted, all the electrics working much better, still no info on the overheating light, door latches lubed and working better than before, grill badge repainted.. Been driven on trade plates, is over boosting and running slightly rich, have reset the ecu need to set the "basic" setting for the actuator, and then the greddy profec 11 will control the boost better.. then oil change and the biggy, THE MOT ... regards rickyhome of the "mad maestro"
Sorry I thought it may have been a turbo conversion before an EFI turbo one. (turbo would have run the autochoke ECU).
Does the temp gauge read high or is it just the overheat light? The if it is the latter then it could be a faulty dash.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Dan the temp is spot on, just the overheat light comes on, later in the week when I mot it I will check the temp with a probe, I have realised the water system flows well but the turbo part of the system does cause some issues, its non std as well... when the radiator is rebuilt I am getting a new inlet made so that the turbo part flows better, but I don't think the turbo is causing the overheating light issue, was after some info as to how it works, so that I can assess if it is the light or the wiring or the dash.. regards rickyhome of the "mad maestro"
It is simply a resistor that alters with temperature. Usually something like 2k ohms when cold and 200 ohms when hot I think.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
have done the mot, so all on the road again.. boost nearly all sorted, the mixture was a dodgy lambda sensor, just need to drive it now to get every thing to settle down, that clutch is so heavy I have a pedal shaped mark on the ball of my foot.. just need to give a good clean and valet, then ready to sell again.. regards rickyhome of the "mad maestro"
