Sump drain plug
  • Sump drain plug
    Hi can anybody help me I am searching for a oil drain plug and washer for Austin meastro 1600 a series
    Hi meant Austin meastro 1600 s series
      If you have the old one for a pattern, it should be possible to find one from another vehicle that is the same, an engineering place or bolt stockist should be able to measure it and identify the thread. I'd guess that it might be a metric thread, so will be the same as a variety of other vehicles. If you haven't got the old one, I'll see if I can find out what it is.
        Hi thanks for your message I haven't got the old one
          I'll have a look and see what I can find...
            They seem to be the same as quite a lot of Rover engines https://www.ebay.co.uk/itm/ROVER-Car...wAAOSwy~Jb0H42
              Thanks for checking that up for me I will get that one and see if it fits cheers
                i think the prima has a 1/4" bsp plug and the mini has 5/8" unc plug. i could be wrong but that ebey listing has that plug fitting both.
