Diesel lift pump replacing diaphragm
  • Diesel lift pump replacing diaphragm
    help
    That doesn't say much thart. What's the problem?
    1958 Ford Consul Convertible, now being used
    1965 Ford Zodiac Executive. now being used
    1984 MG Montego EFi in black. Digital dash, Welding completed
    1984 MG Montego EFI in red. Digital dash, now sold
    2004 MGZT V8. Back on the road. now being used
      The older type of lift pump had a diaphragm with 2 notches in the shaft, it could be removed by turning it a 1/4 turn to release it, later ones have a slot in the shaft and I cannot see how to release it from the pump body, I have a repair kit but until I find an answer to this I cannot use it.
      Thanks for answering my enquiry Jeff
        oh i see, you have a kit, they where NLA last time i needed a pump. i did not know about the later pump having a slot. if you remove the pump and clean off the old gasket you will see the two wedges holding the pump together but the pump body will have been hammered over to stop them coming out. same for the valves, if your kit has new ones you will need to use a punch to fix them in place.
          Thank you again Robert, I have fixed many of the older type over the years but the new type foxed me, your solution looks like a perfect answer.
          I am tempted to go for the new pump that you suggested and once that is up and running, I can repair the existing one at my leisure as a spare.
          This should reduce downtime hopefully.
          Very many thanks T 2 sheds
