1985 MG EFi engine is blowing the crankshaft oil seal out of the oil pump housing. Just wondering if the crank/camshaft wheel combination is wrong for the engine as the EPC shows that there should be a flanged washer each side of the cam wheel on the early engines and this one hasn't got that.
Front oil seal blowing out
Membership Secretary
You know you are getting old when your knees buckle and your belt doesn'tTags: None
Originally posted by Sussex Pete View Post1985 MG EFi engine is blowing the crankshaft oil seal out of the oil pump housing. Just wondering if the crank/camshaft wheel combination is wrong for the engine as the EPC shows that there should be a flanged washer each side of the cam wheel on the early engines and this one hasn't got that.1958 Ford Consul Convertible. I love this car
Is it oil weeping out of the crank seal or the oil pump gasket?Membership Secretary
I would say you have the wrong oil seal in place or the breather is blocked as that shouldn't happen. On my early engines I don't have an extra washer to keep a seal in place.1958 Ford Consul Convertible. I love this car
Three times so far. I think pump and breather will be the next areas to check, once a new seal has been sourced and fitted.Membership Secretary
I had exactly the same problem on a Rover 214 many years ago.
A new seal made no difference.
Thoroughly cleaning the housing and new seal with brake cleaner, followed by the gentle use of fine emery cloth on both and then a smear of Superglue around the seal finally did the trick. I did not start the engine for a couple of days, just to give everything a chance to set.
Approx 7 years and 75000 miles later I sold the car. Not a single drop had leaked out!1983 (Y) MG 1600
1987 700 City 1.6 Van
1988 Tandy camper 2.0D
1990 Clubman D
1990 MG 2.0i (spares donor)
(all Maestros)
Daily drive: Rover 25 GTi
