I have just received an email off PAW Engineering letting me know that he has the materials, and the programs are written to produce some more of his big brake kits which is great news. Now I need to start gathering the rest of the parts of the maestro braking system so it would be a great help if anyone has the part numbers. I want everything replacing so the whole system is new. On googling most placed that are advertising parts are out of stock. It will make it a lot easy tracking down the parts with the numbers unless anyone knows of somewhere that sells them all. The garage it will be going to will have the copper pipe I should imagine. So, I should need:
I have seen a braided brake line kit so that’s sorted. Is there anything I have missed regarding braking components? Obviously, the big brake kit includes the front disks. All to fit MG Maestro Turbo. Thanks in advance Andrew
- Callipers right and left (Are these the same as the 2.0 Montego? As I have found a few for sale for Austin Montego 2.0 but not for the Maestro)
- Pads (Which are the best available? I see they once did greenstuff pads can’t find any now. I like using Ferodo ds2500 but I can’t see them doing them for this calliper. Do MGF pads fit?)
- Rear brake drum
- Rear brake shoes (Can you get upgraded ones of these?)
- Rear wheel cylinders
- Brake master cylinder
