Maestro/montego fuel filler neck
  • Maestro/montego fuel filler neck
    Does anybody know if the maestro petrol cars had the same fuel filler neck pipe has the diesel cars
    The filler necks changed over the years as unleaded petrol came in to replace leaded, unleaded has a smaller neck. I'm not sure if the diesel pipe is wider or not compared to unleaded. An older type unleaded would fit I should imagine if you can get one
      Thanks for the info Jeff I will start looking for one hopefully I will find one. When the car was hit it was petrol everywhere the filler pipe is damaged when they assessed it I will have to renew from the filler to the tank if I want to get it back on the road
        Easiest way is to get one fabricated and reuse the top part. Exhaust fabricator should easily be able to do that for you
