Tested my pres reg today,not sure if it duff. I thought when the pump primes the pressure reg should be closed? When I primed mine fuel came out of the spill port pipe,not a huge amount but im concerned its not seating correctly. Also when I removed the fuel rail I put a vac pump on it but it did not release a huge amount of fuel.
I have a brand new montego one the one from the later cars which sits on the end of the round cast bus rail located by two bolts.
Has anyone got one that is known to work from a car with the square section bus rail where the reg is a push fit on the rail and a screw union to the spill pipe.
A very hopeful Russ!
07798 576081
07798 576081
