Originally posted by Doctordiesel77
View Post
Wrong cylinder head gasket!
Does sound annoying, I've got quite used to oil leaks due to mostly running diesels and Land Rovers, but still get very annoyed by oil leaks on my other vehicles, ie the ones I've looked after / rebuilt.. As Jeff says, it is not a major job, apart from the possibility of broken studs...I'd forgotten about them, my knuckles have healed up after the last ones ha ha! I haven't done anything with my 1600 yet, but my plan is to follow the manufacturers instructions then, if it still leaks I will fit an external oil feed, like they used to have in the good old days and seal the existing feed holes up completely, this might be a bit too drastic for you, unless you like taking engines in and out.... I guess keeping a good stock of gaskets could be a good plan though..
It's started to leak onto the floor now, not much just a drop a week, I have to assume it'll be getting worse. I check the oil level everytime I go for a run and there's no noticeable change, will get me a drip pan for garage floor (old piece of plastic mat at moment) and try and gause how much I'm losing. Also gonna spend some time on gathering views, reports, etc from other Montego/Maestro owners who've had similar issues. Apart from that runs fineOriginally posted by Jeff Turbo View Post
As John says, it won't damage anything as just an annoying leak. Changing a headgasket is quite easy but you'll also need another manifold gasket. If taking the head off with the manifolds attached mind out for a broken stud thay attaches to the downpipe as they can snap easily. While changing the gasket I would also change the cam seals and any core plugs you can get to
well, with all the rattles and shakes of course
BTW have 128.000 kms on the clock (about 88.000 miles in old money)
