What are the old unipart numbers for Montego 1.6 1988 clutch .
Clutch Part Number
Clutch Part Number
1979 Triumph Dolomite 1500HL Pagent Blue From new 76.000 milesNow out of Hibination and into RestorationTags: None
New part number URF008083EVA Rimmers have them at under £30.
Old part number is (I think but can't remember) GCK401AFM&MOC Committee Member - Archivist
Simon.Someone on ebay has GCK148AF and someone else has it as GXK148AF are these the correct ones
Also can you link to the rimmer part pleaseLast edited by TLC; 2nd July 2015, 15:15.Sure & steadfast.
Yes these should all fit. GXK I believe is a typing mistake
www.rimmerbros.co.uk/Item--i-URF008083EVA
www.rimmerbros.co.uk/Item--i-GCK401AF
www.rimmerbros.co.uk/Item--i-GCK148AF
http://www.ebay.co.uk/itm/ROVER-MG-M...-/350127971259
http://www.ebay.co.uk/itm/AUSTIN-ROV...item51863f1a1dM&MOC Committee Member - Archivist
Ive gone for this;
http://www.ebay.co.uk/itm/ROVER-AUST...item1c50d39644
The GXK apparently iis a remanufactured clutchLast edited by TLC; 3rd July 2015, 13:21.Sure & steadfast.
Originally posted by TLC View PostThe GXK apparently is a remanufated clutch
Check before fitting that none of the reluctor teeth are bent inward as a result of it being dropped at some point.Last edited by Simon; 2nd July 2015, 20:48.M&MOC Committee Member - Archivist
Unipart clutch arrived this morning and cars booked in thursday to have it fitted
The guy sent 2 clutches as i had said i may want another as a spare.However he sent a motoquip one on the pressumption that i wanted it .I would have wanted another unipart one the same as the one i paid for so iam not paying for it .Lets see what he sugestsSure & steadfast.
Check inside the box, could well be exactly the same part.
There are two clutch sizes I seem to recall on the VW box. So long as you have the right one then all will be well.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
All ok so far .Simon How do you find out what size the clutch is seeing as there is two sizes for a vw box,I seam to remember i previously had a wrong sized rover one URF008082EVA As another garage wouldnt fit this so went out anf fitted another brand in 2011.That number is one out of what you mentioned in your previous post
Therefor what dose this belong to ;URF008082EVA ? As i would like to sell itLast edited by TLC; 12th July 2015, 11:33.Sure & steadfast.
There are 2 sizes of clutch - 190mm and 200mm. No idea of the application of URF8082 yetM&MOC Committee Member - Archivist
8082 was for the 1.3
8083 was for the 1.6 so I suspect that is the bigger one for the VW box.
http://www.rimmerbros.co.uk/Item--i-GRID018347www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Thanks for the info .I can put it up in the sales for a 1.3 Montego.I presume is the same for a Meastro ?Sure & steadfast.
Yes except for the van which had the bigger plate I believe.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
