It seams that the Idleing is still a bit out but that can vary weather its cold enginge or a warm engine .It starts ok .It hasnt cut out yet but when aproucing a juction i get the feeling that it may stall as it labours a bit .I have had the carb center tweek the revs a bit as ive never meessed about with them and they have said i can tweek it a bit more but what i want to know it will this upset what the ecus do.
Idleing
John.
Everything was replaced new when i had a non starting issue and the fault was the carnk sesnor wireing so it should be a case of just fine tuneing as the carb was serviced as well and set up at the carb center .Sure & steadfast.
