Well the worst situation has happened.. The oil pump appears to have failed on my turbo engine and I don't know what to do. Can it be repaired? Can I use a later pump from a T series turbo? I know the montego ones are NLA but was hoping someone had come across this issue before? Thankfully the oil was pumping prior to being taken off, it was only when I went to restart it the light wouldn't go out. It was immediately turned off and then stripped down.
Photos attached showing the centre and it is really sloppy! I've tried to show this on two shots:
I would be happy with a decent second hand one, this one just seems not right.
Thanks.
Thanks.
