Hello people,
so i've just taken hold of a D reg montego and its awesome but when you plant the throttle it luggs down really bad and doesn't pickup. if you feather the throttle its seems ok but somethings not right
first i've read about the Temp light flashing, previous owner had given me some spare control units, i tested with two others but the light starts flashing with ignition on and cold
I bridged the temp sensor connection but the gauge didn't move - is this a fault of the 9015 controller or is it the dash clocks??
also when the engines running, disconnecting the temp sensor caused the engine to nearly stall out - again is the 9015 controller or the carb mixtures all wrong ??
any help would be much appreciated
JBO
JBO
