Can anyone help Benigno, message below
Hello,
"I have a technical problem, and I would appreciate your advice. The spring of the lock in the trunk is broken. I want to change it, I have no problem to disarm the lock, but I can not remove the central part of the lock to put a new spring. I see a bolt in the lock, but I do not know how to remove it. Probably if I can remove this bolt, I can remove the central part of the lock, and place there a new spring.
Thanks you very much in advace for any advise with this problem.
Best regards,
Benigno Rodríguez."
Hello,
Best regards,
Benigno Rodríguez."
