After asking on Facebook and not really getting anywhere I thought I would ask here, I don’t seem to have any dash lights illuminating when the ignition is turned on, after doing some digging I found these wires in the passenger footwell but am unsure where they may go, I’ve done abit of tinkering, pulled the ignition cowling to make sure the ignition switch is ok, pulled the fuse board which is still as fresh as it left the factory, car will turn over but not fire, pulled the board out from above the glovebox but the connections are not from there, a wiring diagram seems to show the wires as ignition ?
I’ve also checked earth I can see under the bonnet but still drawn to the wires in the passenger footwell, the car is a 94 model 2.0 LXi
the green wire is next to the radio loom, the white plug by the écu, I’m wondering if something is missing
