Hello,
I have some faults in my montego.
When I turn left and accelerate it makes me a clock clock clock which I suppose will be the short external transmission.
Does anyone know where I can find it?
Another part is the rubber on the top of the shock absorber that makes contact with the chassis. It is very worn and causes the shock absorber rod to protrude more from its housing.
Does anyone have the measurements to make a new one in polyurethane? Or do you know where to get them? . I am interested in making them in polyurethane since I have a threaded suspension.
The last fault is that when I am going to reduce a gear at the moment of half the clutch pedal when the friction of the disk is starting, a tremor is noticeable and it is only felt at that moment. Could it be the flywheel? The clutch has 20,000 km.
Thanks you
Thanks you
