Hi All
I experience big problem over the weekend with my Series 2 Land Rover with 2.0TD conversion.
I've been searching on here and it's almost identical problem to this old post below. One minute running fine and the next almost total loss of power, popping and knocking like hell and smoke pouring out the back.
Diesel Fuel lift pump problem? - Maestro & Montego Owners Club
So my first thought was the lift pump had gone but today I checked the strainer, that was clear and if I pump it manually it will delivers fuel to the vent plug on the filter. There is a new filter fitted and that's been in for about a year.
Is it possible that the problem is still the lift pump but it will just manage to manually pump fuel as far as the filter. Not sure what the pressure is supposed to be after the lift pump?
Also are replacement lift pumps available anywhere?
Of course any other ideas of what it might be are welcome. I've read lots of very similar posts on the forum.
There's no EGR by the way.
Martin
Martin
