montego diesel pump seal kit needed
  • montego diesel pump seal kit needed
    hi all,i've seen the informative member write up on how to change the end seals [where the feed pipes go to the head] ,but i cant seem to find a kit anywhere, i did email darwen diesels,but they need a number off the pump,i cant see one ? any help gratefully appreciated,thanks pete
    Hi Pete
    I know nothing about diesels but the good doctor diesel should be on here soon to assist
      If you search ebay for bosch ve seal kit you should find a lot of them, I think the kits fit most variations of the ve, Darwen diesels are probably being a bit overcautious making sure they get the correct parts. iirc the pump number is not easy to see with the pump fitted to the engine.
        thanks for your help dr.diesel,parts ordered
