Maestro Van Brake discs.
  • Maestro Van Brake discs.
    These are often wrongly listed as being car ones, or vice versa, the original part numbers are GBD90821, GBD90812, NAM4157, GBD90808, there are 4 fixing holes on a 4" (101.6mm, often mistakenly listed as 102mm!) which are tapped m10. Ferodo DDF282 is listed as fitting cars, but is in fact a van disc, the list of numbers is lifted from an internet listing for ferodo discs, the ones I've checked all have 4" pcd and are van discs, be wise to double check befor buying, but I'm very confident that they are all van numbers..
    PRODUCER REFERENCE
    ABS 16118
    APEC braking DSK263
    AUSTIN NAM4157
    AUSTIN GBD90808
    BENDIX 561494B
    BENDIX 345061B
    Brake ENGINEERING 952940
    Brake ENGINEERING DI952940
    BRECO BS7365
    BREMBO 08496720
    BREMBO 08.4967.20
    DELPHI BG463
    DELPHI BG340
    DELPHI BG2463
    ferodo DDF282-1
    ferodo DDF282
    ferodo DDF282-1
    FIRST LINE FBD337
    LPR A4291P
    MINTEX MDC412
    Motaquip VBD376
    NATIONAL NBD020
    NECTO WN580
    QH Benelux 57494
    QUINTON HAZELL BDC3576
    QUINTON HAZELL BDC3576P
    REMSA 675110
    ROADHOUSE 6751.10
    ROVER NAM4157
    ROVER NAB9620
    ROVER GBD90821
    ROVER GBD90812
    ROVER GBD90808
    sbs 1815201215
    TRW DF1899
    Unipart GBD90821
    Unipart GBD821
    some more information
    Ref.: GBD90821
    name: Brake Disc Front Axle
    Height : 32.5 mm
    Diameter : 240 mm
    Centering Diameter : 68 mm
    Pitch Circle Diameter : 101.6 mm
    Brake Disc Thickness : 12.7 mm
    Minimum Thickness : 11.4 mm
    Num. of holes : 4 Solid or Vented : S
      What's the difference apart from 22mm vented and a 12mm solid front brake disc?
      I want to fit vented 22mm discs to my 83 Y mg 1600, it has a 12mm solid disc.
      is the brake caliper for a vented disc wider/bigger than the solid disc caliper?
      like above, it's a bloody mine field when sourcing standard brakes or upgrading.
      I've always used an EBC green stuff pad when an ABS system is not on the car, those pads alone make one hell of a differance.
      can anyone shed any light on my above ramblings?
        The car parts are all interchangeable, for vented discs you'll need the wider caliper and carrier, the pads are the same though. The diesel Montego estate had ventilated discs, so if you find anyone that is breaking one it will have the parts that you need.
          Spot on. ;-)
