Maestro Van Brake discs.
Originally posted by Mr bump View PostWhat's the difference apart from 22mm vented and a 12mm solid front brake disc?
I want to fit vented 22mm discs to my 83 Y mg 1600, it has a 12mm solid disc.
is the brake caliper for a vented disc wider/bigger than the solid disc caliper?
like above, it's a bloody mine field when sourcing standard brakes or upgrading.
I've always used an EBC green stuff pad when an ABS system is not on the car, those pads alone make one hell of a differance.
can anyone shed any light on my above ramblings?
some more information
Ref.: GBD90821
name: Brake Disc Front Axle
Height : 32.5 mm
Diameter : 240 mm
Centering Diameter : 68 mm
Pitch Circle Diameter : 101.6 mm
Brake Disc Thickness : 12.7 mm
Minimum Thickness : 11.4 mm
Num. of holes : 4 Solid or Vented : S
These are often wrongly listed as being car ones, or vice versa, the original part numbers are GBD90821, GBD90812, NAM4157, GBD90808, there are 4 fixing holes on a 4" (101.6mm, often mistakenly listed as 102mm!) which are tapped m10. Ferodo DDF282 is listed as fitting cars, but is in fact a van disc, the list of numbers is lifted from an internet listing for ferodo discs, the ones I've checked all have 4" pcd and are van discs, be wise to double check befor buying, but I'm very confident that they are all van numbers..PRODUCER REFERENCE ABS 16118 APEC braking DSK263 AUSTIN NAM4157 AUSTIN GBD90808 BENDIX 561494B BENDIX 345061B Brake ENGINEERING 952940 Brake ENGINEERING DI952940 BRECO BS7365 BREMBO 08496720 BREMBO 08.4967.20 DELPHI BG463 DELPHI BG340 DELPHI BG2463 ferodo DDF282-1 ferodo DDF282 ferodo DDF282-1 FIRST LINE FBD337 LPR A4291P MINTEX MDC412 Motaquip VBD376 NATIONAL NBD020 NECTO WN580 QH Benelux 57494 QUINTON HAZELL BDC3576 QUINTON HAZELL BDC3576P REMSA 675110 ROADHOUSE 6751.10 ROVER NAM4157 ROVER NAB9620 ROVER GBD90821 ROVER GBD90812 ROVER GBD90808 sbs 1815201215 TRW DF1899 Unipart GBD90821 Unipart GBD821 Tags: None
