Has anyone gone down the road of fitting a high level brake light on a Maestro - particularly on a Turbo? I've been mulling over the idea of fitting one inset into the trailing edge of the roof spoiler, if I can find one that is narrow enough! Just thinking that in todays traffic, where the vast majority of cars now have these as standard, there is always the possibility of being rear-ended by someone who isn't looking at the rear light cluster for brake lights.
High Level Brake Light - Anyone fitted one?
Membership Secretary
You know you are getting old when your knees buckle and your belt doesn'tTags: None
I used to have one fitted inside the top of the rear screen. Simple to fit and remove if you wanted to make it original again.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
i fitted one in the mid eighties but the bulb kept breaking i guess the shuting of the tail gate banging down did it no good
but i guess the led bulbs used now are much better as the light unit i had used the one shaped like the interior bulb and not very strong
Originally posted by E_T_V View PostI used to have one fitted inside the top of the rear screen. Simple to fit and remove if you wanted to make it original again.Membership Secretary
I fitted a Hella high level brake light to my Maestro, probably in 1989. It did come loose leaving the black stick on surround on the glass so I stuck it using clear silicone with then worked perfectly as an invisible mend thereater.
I recall that a Rover 75 estate brake light can be fitted to the upper edge of the Maestro tailgate. I'm sure this was done by Nick Bonthrone at Austin Garages.Last edited by Simon; 22nd August 2016, 13:19.M&MOC Committee Member - Archivist
It wasn't this one but it was similar. LED that stuck to inside of rear window.
https://www.amazon.co.uk/Ring-Automo.../dp/B008CENXZU
Originally posted by E_T_V View PostIt wasn't this one but it was similar. LED that stuck to inside of rear window.
https://www.amazon.co.uk/Ring-Automo.../dp/B008CENXZUMembership Secretary
That unit isn't waterproof so not really suitable for external mounting. Inside the car is much more simple. You can integrate on into the rear spoiler but it'll be a LOT more work.
I've got one in the spoiler on my 600 which would probably suit but too much like hard work making it fit as the turbo spoiler is very hollow.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Originally posted by E_T_V View Post.....as the turbo spoiler is very hollow.Membership Secretary
I've got a screen fitting installed by a previous owner. There is no obvious branding on apart from mycarr stamped in the plastic lens. It is on the tailgate frame rather than the glass and is very discreet, so much so that it took me a long time before I realised it was there.
That looks very neat Nick. I can see this being copied by me as long as it will be visible under the Turbo roof spolier.Membership Secretary
Yeah it'll still be visible.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
