Does anyone know if the collectors between these two models are the same? I want to suppress the catalyst of my icat
doubt about exhaust manifolds between icat and efi
The manifold is the same, part numbers for your catalyst exhaust system are: front pipe, gex12013, catalytic converter gex8048/gex8016, centre pipe gex33567, rear pipe gex33421. Non cat system, front pipe gex11013, centre pipe gex33225, rear pipe gex33222/gex33421/gex33568. so the only parts you need will be centre and front pipe, or you could just weld a pipe up to replace the cat?
good luck
John
Microfiche for GEX 33090 specifies EFI saloon Vin No 199838 to 265881. If your car is later Vin No it could be modified to fit._____________________________________________
Current Fleet
there are some on ebay, a lifetime supply is cheaper than one pair, but not sure if they post to Spain. https://www.ebay.co.uk/itm/Austin-Ro...tfE5:rk:9:pf:0. and. https://www.ebay.co.uk/itm/Austin-Ro...~mhC:rk:1:pf:0
I bought the exhaust manifold with reference gex 11013 and the output is 47 mm in diameter. this muffler would adapt properly to form the complete exhaust pipe efi?
this is the referece
Intermediate exhaust silencer Austin Montego MG 2. 0i EFI - Vanden Plas - Family 1994 cc. 115 HP from 1985 to 1991 similar to GEX33090
