UNF or Metric nut?
  • UNF or Metric nut?
    I need to get a new nut to fit an anti roll bar link. Only problem is I don't know what nut to get. I don't even know if a 1989 Maestro would use metric or UNF thread? The thread itself is 13mm in diameter, not sure of nut size. I am assuming it will need to be a lock nut?
    Any help gratefully received.
    It is metric from memory. Almost all the nuts and bolts on the maestro are metric.
    A nyloc nut is probably the best option with a suitable washer.
    I doubt the thread is 13mm diameter. I would guess it is more likely a 10mm or 12mm diameter (which would be M10 or M12 respectively as I think the thread pitch is standard).
    If you are lucky I am trying to find one in my garage tonight/this weekend to send away for re-manufacture, so I'll measure the thread and diameter then so you can be sure to get the right think.
      Confirmed its an M12 Coarse thread nylock nut. 19mm across the flats. Part number is NY112041. Rimmers have them in stock for £1 inc vat.
      Membership Secretary
        thanks !
        Thanks, I have ordered from Rimmers. Life does seem to be easier when you know the part number!
