Can somebody help me out ? On a RHD Maestro, headlamps, bottom left on glass is an arrow, under that are 4 numbers then to the right 3 numbers. Would anybody be able to tell me which direction arrow points (as you look at headlight) and what the numbers are, both left and right lights. Thanks Chris
Headlamp glass text & numbers
See attached photos. The writing was on the right hand side of each glass though, not the left? The numbers on the drivers side (assuming UK right hand drive) are 7837 and 106. Passenger side numbers 7838 and 107.
Anything else required just let me know.
IanIan Drew
Originally posted by ian drew View PostSee attached photos. The writing was on the right hand side of each glass though, not the left? The numbers on the drivers side (assuming UK right hand drive) are 7837 and 106. Passenger side numbers 7838 and 107.
Ian
