Hi
If my Masetros been stood a week when I first try to start it I have to turn it over longer than I would expect and get a large puff of oil smoke out the back... stood only a couple of days its fine and it aced the emissions on the MOT.
Does anyone have any thoughts, Im hoping valve stem seals as the idea of piston rings scares me. I was going to take the head off try and confirm this while its laid-up, is there a better way to confirm without removing the head. If Im going to remove the head is there anything else I should do at the same time. Also if Im removing the head is it worth replacing with something newer, there are plenty of places selling uprated replacements for the mini cooper (I believe they are similar?? Can anyone confirm this).
I realise this means it may not be origional, but as its a 2001 ledbury it feel new enough to play with while keeping the spirit. (I would be tempted to make a hybrid maestro if I can find a dead prius cheap enough).
1.3 A+ Series with 59K
Thanks
Thanks
