Quaife diff ready to go into gearbox:)
  • Quaife diff ready to go into gearbox:)
    Removed my diff from the Rover gearbox today, It was a simple job and now time to strip the Maestro box clean,paint and change all the bearings before the diff goes in.
    A few pics to be going on with
    Simon.
    If its from a rover box it will be a torsen not a quaife, there were 2 types of torsen type a and type b, the types a's are a slightly better diff bit are renowned for sheering, the type b is stronger and still a good diff. I did the same with my efi box fitted an lsd, in my t16 best thing I did
      No its a Quaife as bought new and fitted into a Vitesse. Its done around 4000 miles since new but is now ready for my Maestro
      Simon.
        Definatly looks like a quaife to me.
        Certainly not a torsen type A or B.
        Remember to change the speedo ring for the right one for the maestro otherwise the speedo will be wrong.
          OK thanks will remember that. It is a Quaife which was bought through Demon Tweeks.
          Simon.
            Top is the 200/400 T16 speedo ring
            Middle is the 600 T16 speedo ring
            Bottom is the Maestro speedo ring
            The 3 types of standard diffs fitted
            Left is the type A torsen fitted to 200/400 turbos
            Middle is the standard open diff
            Right is the type B torsen fitted to the 600 turbos (and 800 too I think).
            Lots of other rebuild pics in that picture set with a few comments which may or maynot be helpful!
            http://www.flickr.com/photos/7818304...7629659916441/
              hope it lasts better than the torsen diffs. My vitesse (which being a 1998 had the type b) ate its diff at 110,000 miles. Did work still but very noisy when taking up drive (clonk) have used a standard 820 gearbox now. Drives quit nice little more revs on the motorway but much better around town as 5th is not so long. Spins the wheels up alot now though
                If you kept the old box then it is worth recovering the diff as it is usually not the diff that is at fault. If I was closer I'd have the scrap box!
                  Thanks, Although the box was reconditioned when the diff was fitted im going to change all the bearings for new when i rebuild it. (steel cage ones too
                  Simon.
