Hi all hope someone can help! On the carb I've got it has a dyphragram cold start thingy, can I bypass this by linking to two outlets together or should they be blocked off? And how does this affect cold starting?
Also is the fuel shut off valve a solid unit? On mine the pin on float side moves in a few mills before it pushes up - is this normal
Thanks in advance
Ed
Thanks in advance
Ed
