I picked up a new door yesterday, I think it is a maestro door, can I fit the montego door trim to this easily enough? I've never stripped a door down so not sure if the fittings are the same?
differences in doors maestro to montego?
Front's are identical, only thing is the maestro door will not have the locating dowels on the top for the Montego trim.
Easily rectified by using rivets to hold the clips in place.
Rears are essentially the same across the range, until you get to the window frame.
All three have differing window frames on the top,(due to body angles at the rear, the frames needed to match) but the base units are identical.
You can with care, swop the frames over on the base unit's, to use any rear on any car.
