Gone.
Wonder if these would fit....
You need to know the offset to have a better idea of fitment. Something the seller doesn't mention in the ad. Usually eg. et50 or another value.
I forget what offset you need for the monty. Being these are deep dish wheels you might need to roll the wheel arches to stop any fouling of the tyres.
They may fit, but it depends on how much modifying you are prepared to do.
By the dimensions the seller gives these have an offset of ET5. So these will stick out past the front arches. Especially if you have wide tyres on. Not by much but depending on the ride height/camber etc they may look stupid
No spacers required due to the low offsetLast edited by g200mss #146; 26th May 2015, 17:05.
The fwd version of this wheel was used on a dealer special at a garage in guisborough back in the 80s. They were white colour coded 2.0i maestros and montegos.
They used to look very good but these are red offset so would look odd and handle badly
