window lift switch connectors
  • window lift switch connectors
    I have a set of Front & Rear swtiches but the bases /conector are differant .The Fronts have a multi plug connectopr but the rears have a srt length of wires solderd onto the switch terminal then a white round pin plg and a square black plug would these rear switches be earlyer than the front switches .Has any one got the later rear switches pre face lift models 89
    Sure & steadfast.
    Sure & steadfast.
      Found some more with connectors on so all ok
      Sure & steadfast.
