If you need to rebuild the vacuum system on a 1.3 Maestro or Montego with automatic choke then these diagrams should hopefully help. You'll need two guages of pipe and some T and L connectors but at least this will help you assemble it.
There was a revision during production - the earliest ones had a vacuum pipe leading to the heater matrix. Where this was deleted later on, the main plastic connector had one of its ports blocked off.
